Octanerender 1.0 Plugin For 3dsmax, Maya And Smith Micros Poser (win64)
snowwhite9551
28 Ara 2012
snowwhite9551
OctaneRender 1.0 Plugin for 3DsMax, Maya and Smith Micros Poser (win64) | 63 MB
Octane Render is the worlds first GPU based, un-biased, physically based renderer. It uses the video card in your computer to render photorealistic results fast...really fast. This allows the user to create stunning works in a fraction of the time of traditional CPU based renderers.
ENGINE
Physically based / Spectral Light Transport
Unbiased and Direct Lighting / Ambient Occlusion
Custom Sampling Algorithm (Custom MLT-like implementation)
Multiple GPU Support
Geometry Instances
Pause / Resume render
Built-in Firefly removal tool
Deep Channel kernel mode to provide renders for geometric normals, shading normals, z-depth, material ID, UV co-ordinates
SPECTRA
Supports multiple colour spaces
RGB colours
Gaussian spectra
Blackbody spectra
TEXTURES
Image textures include support for loading over 40 different formats
HDR, Canon RAW, and OpenEXR HDRI image textures
Output of real-time GPU tone-mapped images
Output of raw HDR images (exr)
LIGHTS
Spectral Sun / Sky daylight with real-time location / date control system
Spectrum or HDRI environment lighting
Customizable texture and blackbody spectra emissions from geometry with controls for temperature, power (watts), distribution, efficiency
Support for IES light files
MATERIALS
Physically based material models
Bump and normal mapping
Opacity / Alpha mapping
Transmission, absorption and scattering
Mappable Thin Film Coatings
Null material and mix/stacking of materials and layers
IOR and Chromatic dispersion for specular materials
Access to LiveDB Material Database to quickly add community submitted materials to current scene
TONE-MAPPING
Full GPU based real-time tone-mapping pipeline
A selection of measured camera response curves
Simulated camera controls for exposure, F-stop, ISO
Controls for gamma, saturation, vignetting
Thin lens perspective with true DOF
Realtime 3D Anaglyphic Stereo Rendering
Real-time control of DOF
Lens Shift
Interactive focal-length adjustment (specified distance or auto)
USER INTERFACE (UI)
Real-time interactive editing, monitoring and rendering of scene
Flexible nodegraph based user interface
Build complex procedural objects and materials by connecting nodes
Sharing of material, texture and emitter macros using the LiveDB
Executable command line parameters for automation of rendering
Customisable toolbars, add, remove and re-arrange items
FILE FORMATS
Import of Wavefront OBJ format with parameters and material import
Import supplied vertex normals or calculate them via supplied smooth groups
PLATFORMS
Windows 32 and 64 bit
Linux 64 bit
Mac OS X 10.5+
PLUGINS
Fully Integrated (Additional Licensed Products)
Autodesk 3D Studio Max
Autodesk Maya (open, licensed beta)
Smith Micros Poser (open, licensed beta)
Plus free community developed exporter plugins for:
Autodesk Maya
Autodesk Softimage XSI
Blender
Maxon Cinema 4D
Sketchup
Modo
Kod:
http://turbobit.net/g1eoc4ihgktn/1220130101_OR.1.0.x64.rar.html
http://freakshare.com/files/9zqxou5p/1220130101_OR.1.0.x64.rar.html
